shutter speed dial loosening up
dfoo
5:37 AM
St. John's, Newfoundland
I've been shooting like crazy for the past 3 weeks, and the shutter speed dial on my M4-p has started to loosen up. When I first got the camera, it was very tight. Now it turns very easily, so much so that I'm having to check it to make sure I don't accidently change it. How can I tighten it back up?
dfoo,
looks to me like you take the shutter speed dial off and underneath is a circular kind of screw with 2 cutouts. maybe make a special wrench and while stopping the dial movent, tighten this up
Had the same problem with one of my M4-P cameras (after a "CLA" involving to much oil ...), where the excessive oil had found its way to the screw below the shutter dial. Just tighten that screw slightly and it should work fine again.
