jaapv
RFF Sponsoring Member.
JohnL said:However, like most everybody else, I only use my RF with wide, normal and very mild tele lenses.
I do use my M6 with 200 and 280 mm lenses. And I am negotiating for a 400.On the Visoflex of course. Though, if it still counts a a RF then is a question 😉
JohnL said:Perspective of course depends only on where the camera is. However, with long tele lenses the issue becomes less critical. If you get something framed at (say) 100 yards with a 400mm lens, then walk forwards 50 yards and take a similarly framed shot with a 200mm lens, you'll be hard-pressed to notice much difference in the compression. Both shots will have a distinctly tele-type (!) perspective. Now if you walk in to 25 yards and shoot with a 100mm lens, you'll probably start to see the difference, if the thing hasn't flown away.
Sure you must walk quite a bit. The idea is to get your subject into the picture at the same magnification. However, with the subjects I take with long lenses, I am likely to get gored, trampled, stomped or eaten using a wideangle 😱 😀
