skopar on leica?
If you have a LTM-->M adaptor, it will.
Granted, there won't be proper framelines, regardless of what adaptor or camera you use--therefore, just pick the LTM-->M adaptor with the least obtrusive framelines you want.
M adapter if M Leica, otherwise as Ronald says. Either way, an accessory finder: though if it's put on an M with 28 mm frame lines you can, well, extrapolate.
Yes, my 21/F4 VC lens works on my LTM bodies and on my M body using the LTM to M adaptor and it came with an aux. VF that I use on both body types.
Nikon Bob
