ferider
1) It's cute, well built, quite dense - heavier than I expected; it's also coded as Noctilux and works as such on my 240 (which is a bit sensitive to the exact coding placement)
2) Rear element sticks deep into the camera; if you want to store the lens with focus at infinity, you need a deep lens cap. Also, it has extremely short focus throw.
3) Bokeh is similar to other fast Sonnars that I have, below compared with Sonnetar and my two Noktons. 7Artisans lens' focal length is a little longer than 50mm (55mm?) (same for the Sonnetar, BTW). At around 1m focus distance:
4) Transition across the DOF range wide open, at around 1m focus distance (this test is not for testing focus adjustment - remember, both Sonnetar and 7Artisans lens can be user tuned)
5) Some test pictures close to infinity
5a) test description; first I focus in the center and take a pic ("center"); then I keep the focus and tilt the camera, and take the second pic ("corner"). Below, I compare the 7artisans lens to one of my best other 50s, the VM Nokton 1.5.
5b) center resolution; great at f2.8 and above
5c) field resolution; reasonable at f4 and above
6) Vignetting: mostly gone at f2.8 (zoom into one corner of the "corner" test-pic above):
7) Distortion: just a little worse than the Nokton 50/1.5 (have a look at the flagpole)
8) Extreme corners: it shows Italian flag and smears / never gets really sharp in the extreme corners. This is at f5.6, and compared to the Nokton 1.1:
Summary:
- I did not expect the Italian Flag for a 50mm lens. So, this is not a landscape lens on digital - it cann't hold the water to either Nokton 1.1 or 1.5.
- Nice street or portrait lens, in particular on B+W (yet another one 😱 )
Roland.
Summary:
Roland.
