Valkir1987
I just came up with an idea that I wanted to share with you. Maybe it has already been discussed or presented before, excuse me if so.
When you adjust a focal plane shutter, or another type of shutter. You may wan't to test it with an instrument for sure. I came up with the following.
- Make a consistent illuminated scene or test card. Place the DSLR on a tripod and take a shot with the speed and aperture you want to test. Make sure its correctly exposed.
- Now put the camera in Bulp mode. Place the testing shutter without lens in front of the DSLR's lens. Becarefull not to damage the glass surface. Make sure AF is of, and everything is manually set.
- Press the DSLR's shutter button, release the shutter on the testing speed. And release the button afterwards.
Both shots can be compared, or even measured digitally. If they show the same exposure. The speed of the tested shutter should be correct.
