explanation
explanation
E = (gamma)*mass*velocity
Here gamma is a relativistic factor that is greater than unity. So, one could consider the
factor (gamma)*mass a new mass...
Now for DOF:
I'm not doing any cropping on the M8,
the M8 with it's 32.4mm diag. sensor is what it is.
The M8 has the lens I selected for it, and the
distance I selected for the view I wanted.
The legacy film camera using the same lens on
the same tripod gives some "overscan" that I
don't concern myself with, just as I don't print
sprocket holes when I scan film.
For me, the DOF is the same between M8 and M6. If it's
not for others, can you show me in a paper print?
I've also not had to move my Leica, Zeiss, or CV focus
barrels any *extra* stops when using hyperfocal distance settings
with the RD1 with even smaller sensor than the M8 (~26mm diag) and M4P/M6.
Perhaps folks who carry both FF and a u4/3 while
exchanging lenses see something or have to move
something?
Yes, there was: When using an M-lens on the M8, can you still use the DOF marks for zone focusing as you can on a 35 mm camera or an M9?
Now, the way ampguy ansers this is: yes: DOF is exactly the same. The secret is that he crops both shots, the M8 one in the camera, and the M6/7/P/9 one after printing. Well duh.
While correct, this answer (and the method) is also completely irrelevant.
@ ampguy: And now you're telling us the mass of moving objects gets smaller, not bigger. What are you up to next?
@ all: By the way, Schrödinger's paradoxon states very clearly that you won't know if the cat's claws are in focus until you open the camera back! Ha ha! Made you do it before rewinding!!! 😀
