Brian Atherton
In forty plus years of professional and amateur 35mm and 120 black and white processing, this:
I use my fingers, just a quick swipe downwards when film is hung - gets rid of the excess. I do use a drop of Ilfotol "wetting agent" in final rinse. Never felt the need to try a rubber squeegee or chamois leather.
Godfrey
somewhat colored
1 minute in properly diluted wetting agent as the last stage of the wash, hang to dry in my shower stall: no spots, no scratches, dry and ready to scan in 30 minutes.
G
G
wwfloyd
Photo-Flo for thirty seconds, then hang it. Never had a problem.
Same.
Except for the never had a problem part. When I started, I used the "few drops of Photo-flo" that many people continue to recommend, and did get water spots. Now, I use an amount close to the 1:200 recommended on the Photo-flow bottle. That's over 1ml per 35mm film reel, which is more than a few drops. (Actually, about 30 drops, when checked with a Visine dropper.)
Joao
Negativistic forever
Spinning
Spinning
I often use a variant of the salad-spinner method. With a plastic CD box instead (large box for 120 film).
Detailed description here
https://public.fotki.com/BlueWind/drying-film/
I am always impressed with the amount of water extracted from the film and collected in the the tissue.
Joao
Spinning
Joao
Spavinaw
Just with my fingers. By the way, why doesn't finger rhyme with ginger?
Russell W. Barnes
Final rinse in the Paterson System 4 tank for 35mm and 120 film: 600ml boiled water (or tap water - it's good around here), to which I add an APX100 35mm film-container-capful of Ilfotol, which happens to be 3ml exactly, and agitate by spinning the reel for about ten seconds then standing for about a minute.
Whilst film is in the tank, I run the shower briefly and wash my hands, then hang the film on the shower door top bar. Two fingers once down the film and that's it. Incidentally, I stopped drying the tank with either cloth or paper as I was getting residual chats off the cotton that sometimes appeared on the next film I developed! Just a wash in hot soapy water and dry naturally upside down on the window-sill.
