Highway 61
Revisited
I have been using a stop bath made from regular white vinegar diluted with thrice its amount of cheap bottled water bought at the supermarket (the less calcium-rich I can find, water coming from acid soils areas is fine).
I have been doing this for decades and none of my films or FB wet prints ever had any problems.
Edit : same process as someone wrote above, white vinegar at a 1+3 dilution. One liter in a clean brown glass bottle.
I re-use it ad libitum. I know it's time to make some new working solution when it begins not to smell the acetic acid strongly enough. Can be re-used for almost 100x 135-36 rolls if always kept in a dry, cool, dark place. Cost : less than $1.50.
The trick is to carefully let the tank or the FB sheet getting rid of the the most developer possible before filling the tank with the stop bath or have the sheet soak in the stop bath.
Ditto with the stop bath to fixer stage.
One liter for films, one liter for the FB wet prints in two separate bottles of course.
