M
mad_boy
Guest
Since shortly, I have my darkroom up and running.
Regularly, I have issues with 'defects' that I can not explain.
Today, I printed the same negative 4 times; I did not change anything on the enlarger or timing. Of these 4 prints, 3 suffered from 'white lines' and 2 from streaks (both of these are regular defects).
An example of the white lines can be seen in picture 1 (to the left above the shoulder of the man and on the right on top of the bubble. If there are these lines they are at different locations in each print.
An example of hte 'streaks' can be seen in picture 2, basically in a horizontal band at the head of the couple (most pronounced to the right of her head).
Since both effect change from picture to picture, problems with the negative or enlarger can be eliminated I presume.
Does anyone have any clue what is the problem here???
