R
ruben
Guest
I don't know guys, but something here don't make sense. Perhaps several things.
a) You are supposed to be grown photographers.
b) You are supposed to use silent cameras, not enabling your subject hear the
click - and this sound makes a huge difference as your field of manoeuvre in the erratic case of confrontation.
b-2) You are supposed to complement the silent shutter release, with a non-visual pressing of the shutter knob, using the joint instead of the tip of your finger.
b-3) There is a difference between your subject looking you pointing your camera towards him and your subject actually hearing your "click" and seeing the shutter button being depressed.
c) You are not distinguishing between someone who presents no danger, and someone dangerous, you should haven't selected him in first place.
d) In front of someone dangerous you propose to behave yourselves as the Good Sammaritan telling nothing else but "the truth". The truth there is that you are in physical danger.
e) In a non-dangerous situation you can play the Good Sammaritan and present your credentials to confuse and avoid an embarrasment. But a dangerous situation is something totally different. Identifying yourself for truth of for lie puts you on the defensive, giving grounds for your enemy to advance over you. Yes, in a dangerous situation you are at war - so start thinking accordingly.
Ruben
Ruben
