Good photos all... 🙂
The Leica CL and its Summicron-C 40mm f/2 is one of my all-time favorite cameras. A CL with the 40, the matching Elmar-C 90/4 and a 28mm lens are just about a complete photo kit for 95% of anything.
Over the years, I've tried many different lenses and bodies. I have my third CL now, outfitted with the Summicron's sibling Minolta lenses (M-Rokkor 40/2 gen II and early M-Rokkor 90/4 which is the exact same lens as the Elmar-C 90). A Voigtländer Color Skopar 28mm f/3.5 and external viewfinder completes the kit once again. Of my Leica RF equipment, even including the M9, this CL kit is my favorite. I don't use it enough ... but I won't let it go again. Something about the balance of size, weight, capability, ergonomics, etc is just incredibly compelling to me about this setup.
I've spent years looking for a digital camera kit that can replicate it. Like with the Hasselblad SWC, I haven't found one ... yet. I prefer to work with digital capture now, for many reasons that I won't belabor here. I've found digital camera outfits that replicate other favorite camera combinations—particularly my old favorite "lightweight" Nikon FM setup. But not the CL kit as yet. I have some enthusiasm for a solution to this coming soon, but I'll keep that under wraps until it materializes.
For the record:
- The Summicron-C's direct sibling was the M-Rokkor 40/2 first generations. Both lenses are the same design by Leica, the Summicron-C manufactured in Wetzlar and the M-Rokkor manufactured in Japan. Rendering-wise they are as alike as peas in a pod, with differences between them being more a matter of individual lens variation than archetypical of brand. The one I have is the second generation M-Rokkor 40 which was delivered with the Minolta CLE. It is essentially the same lens optically, but upgraded to mid-1970s multi-coating technology, with a slightly redesigned, lighter weight lens mount. It improves on the older lenses with better flare control, but the differences are subtle. They're hard to tell apart.
- The Elmar-C 90 is a Leica design manufactured in Wetzlar. The older M-Rokkor 90/4 is the exact same lens, produced on the same production line, modulo the front lens bezel markings and the JIS 40.5mm threaded filter mount (same as the M-Rokkor). After Leica discontinued the Elmar-C/M-Rokkor 90mm production in Wetzlar, Minolta took the same production equipment and continued manufacture for the CLE in Japan ... it is essentially the exact same lens still. I've yet to see a difference.
- The biggest failing of the CL is the somewhat fragile mechanical TTL metering arm, which to the best of my knowledge can still be brought to as-new spec by DAG and Sherry Krauter, perhaps others. Sometimes the CL's metering needle in the viewfinder can stick at the top or bottom of the display ... this is due to foam seals which are aging that it runs into. It can still be repaired too.
My advice: If you fall in love with a good CL and any of these lenses, hang onto it. I've rarely regretted selling a camera in my life, but I missed the CL when I sold my first one, bought another a decade later, foolishly sold it again and missed it just as much. Now with number three, I'll hide it in the closet even if I'm not using it and just take comfort knowing its there, next to my favorite Rollei 35S ... 🙂
G
