kengai
what is the Summilux 35mm pre-asph? how it acts on the M-P 240?
by damonsong, on Flickr
by damonsong, on FlickrI can compare with the 35mm v4 CRON and Zeiss 35mm f2 (which is equal in performance to the Leica 35 asph f2, albeit with better distortion).
The 35/1.4 Lux pre-asph (German made version) has no problem with using on a M digital. The profile exists in Leica M bodies => coding is not an issue at all.
At f/1.4 the pre-asph lux image is finely defined but with some glow in the finest structures.
At f/2, it's much better and already sharp, not as sharp as the summicron v4. However it will still equal the previous 35mm summicron versions.
At f/2.8 it's not as clinical sharp as the summicron v4 or the Zeiss, but not much to split them. Despite being less sharp (on a M digital), I prefer the summilux image because it won't bring moiré as much as the other lenses : lots of time saved in post processing.
At f/2.8, not much for the pre-asph summilux user to complain. Will remain less sharp than the cron v4 and Zeiss but not enough to justify one over the other.
From f/4, the summilux has a better resolution than the Cron v4, but not as good as the Zeiss and I suspect not as good as the Cron/Lux Asph.
A great advantage of the pre-asph lux over the modern asph is their zero-distortion.
Drawback: 35 lux (as well as 50 lux) lenses will exhibit a focus shift on M9/M240/M depending on the aperture and the distance. Each lens may behave differently depending on how the designer or serviceman has set up the sweet spot of the lens. This wasn't a problem with film-M's but definitely is with a digital M. I can confirm this from my renewed experience on a M9 serviced less two months ago service at Wetzlar.
Only solution not to be bothered, use summilux FLE lenses or digital-orientated summarit lenses.
I did a comparison recently between a early version 2 Canadian Summilux (in fairly poor condition including a couple of meaningful scratches on the rear element) and a version 2 Canadian ...
I found the v1 render overall better than v2
Yes, I agree, but the v1 is therefore much more expensive.
Erik.
Erik,
I have the V1 and V2 but never did side by side comparison (did not intend to anyway).
Although I did sometimes feel that when I use V1, but I have never been sure. so I got that feeling mostly based on your post, your posted photos from v1 was very nice.
Also saw it was said that v1 has 9 elements? Are you aware of anything like that?
Sent from my iPhone using Tapatalk
Would you kindly do a quick comparison? I can't find any information out there to compare the result of them in detail. Very interesting!
Careful! Some examples of the pre-aspherical Summilux cannot be used on some Leica digital M bodies. If it has the thicker rear element shroud, it can scrape against the inner baffles of an M9, when focused toward infinity.
What are you looking for?
I could do it but I need to know what kind of detail are we targeting.
