Michiel Fokkema
Michiel Fokkema
I used to have the summilux pre-asph but found it not usable at 1.4. Way to soft. I can't afford the APSH summilux versions and have now settled on a summicron asph. 2.0 is fast enough for me anyway.
I actually just did some test shots on my MP240 yesterday. I have to say it they turn out better than I expected, smooth across the frame and can be sharp enough once you step down to 2.8. Below are some of the test shots, I left them un-edit (out of camera bw jpg) so you can see if you like how it renders. Mine is the v2 canada version.
Erik,
I have the V1 and V2 but never did side by side comparison (did not intend to anyway).
Although I did sometimes feel that when I use V1, but I have never been sure. so I got that feeling mostly based on your post, your posted photos from v1 was very nice.
Also saw it was said that v1 has 9 elements? Are you aware of anything like that?
No, I've never heard it. The first version was made from exotic glass, so the lens was very expensive. Therefore it didn't sell. Leitz made a version with cheaper glass, from number 222XXXX. The first version is quite good at full aperture, but the second version is horrible. Later on the lens was improved, but I still find the first version the best. I also like the Ollux hood much better than the later one.
Erik.
Hi, Erik, what about the performance of early version 2 with metal infinity lock.?
I have a 216XXXX in black, but is a versionII.
Probably a goggled one. It can be that it has the good glass. Did you try it?
Erik.
The second version, with numbers from 222XXXX, is horrible. They are black and have metal infinity stops. Lenses of later series are improved, I don't know from wich number.
The first version has numbers from 176XXXX until 216XXXX. They are in chrome. (Some are in black.) These are the good ones. They are made from exotic glasses. They use the OLLUX shade. They are known as "steel rim". These lenses are very good indeed.
Leica M3, Summilux 35mm f/1.4 steel rim (goggles), Tmax400.
Erik.
Erik.
hi, may i ask what s/n your copy is?
thank you, the 1.4 pics are better than i expected/Sorry, I didn't see it until now.
Mine is V2(I think, no infinity lock). s/n is 26798xx.
I wish this can focus closer, and I know the one with infinity lock can do that.
It is an M2 version, no goggles, brass infinity lock. Beautiful at 1.4, very sharp starting at f2, hence no need for a 35 summicron for me.
No, it doesn't just unscrew like on my rigid summicron.
