KoNickon
Nick Merritt
Recently I got a beautiful one of these; postwar model. Only problem with the camera is that using the focusing wheel is a painful experience since it's very stiff; turning the front of the lens instead is also difficult, because the lens front ring doesn't afford much of a grip. So last night I applied some grease to the lens helicals -- didn't remove the lens front element, but by removing the face plate around the lens and turning it to minimum focus I was able to apply enough grease to make the focusing a lot easier.
The problem is that in working the front element back and forth to get the grease distributed, the geared ring that surrounds the front element became disengaged from the sprocket that engages the RF prism assembly. (I should have put the face plate back before rotating the lens, since that would have kept the geared ring in place and engaged with the sprocket.)
So now I have to figure out how the heck to get the RF back in alignment. Last night I got the prisms aligned at infinity (the moon), but nothing else lines up. I've read writeups about having to take the two prisms apart and change them relative to each other (and all the while taking care that they don't fall out). But shouldn't I be able to simply keep the prism assembly together and, by removing the geared ring and turning the sprocket that engages the geared ring, rotate the prism assembly until I find the proper orientation? Seems like disassembling the prism assembly and moving the two prisms relative to each other -- in effect, changing the factory orientation of the two prisms -- is just asking for an extremely long and tedious adjustment process.
Thoughts?
Thoughts?
