Pascal
Looking for opinions on these two lenses.
Tamron SP Adaptall 17mm f3.5
Tamron SP Adaptall 24mm f2.5
They will be used on canon full frame or Olympus 4/3rds SLR's.
Is the 24mm f2.5 considered sharp wide open or does it need to be stopped down to get acceptable results. I am considering this lens as a normal lens on the 4/3rds system.
Is the 17mm f3.5 considered pretty good for use on Canon full frame. How much does it need to be stopped down before you begin to see corners and edges sharp. Is the resolution good for a 1Ds Mk II SLR.
I can get one or the other. Which would be better as a walk around lens for general photography?
What is your opinion of these lenses. How much are they worth - new or used ?
