AusDLK
Famous Photographer
I likes mine jus fine.
Keep it purdy much on ma R-D1 all da time.
"Baseball...baseball...baseball..." (I know, old joke.)SteveM(PA) said:think unsexy thoughts think unsexy thoughts 😱
Plain and simple: unless you leave the hood on, you don't want to leave the cap off. A rigidly-attached hood creates a reasonable barrier between the front element and most anything in most camera bags that might inflict damage there (this has worked with my Konica M-Hexanon 28mm f/2.8 and its brilliantly-designed hood, which in my case is essentially permanently affixed to it). Keep the hood on, and you're (mostly) safe if the camera has a "regular" perch in your bag; otherwise, put a cap on it, or you're taking a risk. The faster the lens, the bigger that front element, and the bigger the risk of damage. I don't need to tell you much more, do I?chrish said:Ooo I have a question. What do people use as a lens cap for their 35 noktons when they take the hood off? I want to try shooting some rolls with the hood off but i want a lens cap since i always just throw my camera in my bookbag
amateriat said:Plain and simple: unless you leave the hood on, you don't want to leave the cap off. A rigidly-attached hood creates a reasonable barrier between the front element and most anything in most camera bags that might inflict damage there (this has worked with my Konica M-Hexanon 28mm f/2.8 and its brilliantly-designed hood, which in my case is essentially permanently affixed to it). Keep the hood on, and you're (mostly) safe if the camera has a "regular" perch in your bag; otherwise, put a cap on it, or you're taking a risk. The faster the lens, the bigger that front element, and the bigger the risk of damage. I don't need to tell you much more, do I?
(This goes for outside the camera bag as well; I've destroyed a few SLR lens hoods in violent lens-to-ground contact, but he lenses themselves survived.)
- Barrett
Gotcha. My goof.chrish said:i think you either misunderstood me or i didnt correctly say what i was trying to say, so here is a second crack at it.
Actually, I like the fact that the included cap works with the hood on-camera; that said, they should have included a cap for the lens alone as well. A third-party cap of appropriate size (Kyle mentioned 52mm) should suffice.the lens cap that came with the nokton only fits when you have the lens shade (is that what its called? hood? i dunno...) on the camera. take the lens shade off and the lens cap no longer fits. i know some people shoot without a lens shade on their noktons and i was wondering what they use as a lens cap or what size lens cap fits the lens when the lens shade isnt attached.
rover said:How far does the front element project forward, do standard filters fit without having to worry about them hitting the front element.
Yes, in a moment of weakness I ordered one.
MikeL said:For those of you concerned about size😉 , I thought I'd post 2 photos to show some size differences. A borrowed noctilux, the nokton, and the summicron asph.
marbrink said:The R4M is starting to look very interesting. It would be possible to use the 28mm Utron and 35mm Nokton with zero viewfinder blockage, right?
kshapero said:i tried both at Photovillage. No blockage as long as you don't put some crazy lens hood on them.
