TRIago
No point in using it on the M9. Get a Rigid and keep the DR for film Ms. I love this lens, btw.
Sent from my iPhone using Tapatalk
the closer focus - 50mm Summicron DR by Jordan Dickinson, on FlickrIt is 2019 today.
I still have not purchased the close focus unit for the DR.
If you have Live View why not just get some close up filters?You don't need the goggles to get the lens into close range, all that needs to be done is to move the lens the close focus from infinity, press the ball bearing down, pull out the focusing barrel and move it to close focus range. If you get it over to the farthest focusing point in close focus range (about 1m) then it will lock up on you and you have to press the ball bearing again to move the helicoid.
Phil Forrest
No issues at all then Raid - if you don't want to use the close range, just attach it as a normal lens. It's only the goggles that complicate mounting (not much) but you don't have those.
There is another way to use the DR in close-focus mode. The distance scale on the lens is very, very accurate -- at least mine is. Just put the camera on a tripod, get a tape measure, set the focus on the distance scale and snap away.
So there will be no damage to the camera this way too?
