ferider
An interesting "business trip" you had, ferider🙂
It's rough, Pherdi, but somebody's got to do it ...
Basically, the Nokton is roughly on par with the Planar at f2. Plus it has all the extra speed when needed 🙂 Which makes it a wonderful general purpose lens. Plus I trust the lensrentals guys to be unbiased when it comes to brand.
Roland.
Roland I agree, Roger's tests are great, but missing one important element: F/5.6 The Planar's WO performance is a bit better on the edge, but they are close, for sure. However I'd wager the Planar is well ahead at 5.6. It's true the Nokton has the "extra speed", but the planar has the two factors which are are more "generally" useful: smallish size and weight, and outstanding performance at daylight apertures.
This thread now has me reconsider the view. What are everyone else's findings regarding field curvature? I may need to test again.
I would definitely be in favor of it if it helped me turn portraits from dead center and still keep what I focus on in focus. People seem to note that it has someone, but I don't know if anyone has tested how much.
One issue I haven't seen discussed is field curvature, which I found rather significant in a few test landscapes I shot at varying apertures a few years back. This was using several cameras (NEX, R-D1, M8, and I think also b&w film).
My conclusion based on the test shots was that I will continue using only my Summicron as a general purpose lens. Smaller size, sharper across frame. The Nokton I have used for low light and for some special applications (like portraits). This thread now has me reconsider the view. What are everyone else's findings regarding field curvature? I may need to test again.
Wonderful photo, Peter.
I mentioned that comparison in the OP, uhoh7. What I find more interesting is the comparison with the Planar at f2.0:
(MTF50 results in line pairs/image height, Astig: difference between sagittal and tangential MTF)
Roland.
Off-topic, but among other interesting points the chart makes me think the "old" Lux 50 f/1.4 still does real well against the latest 50s.
Congrats Raid !
Roland.
It may do, but not in that test, the actual lens was Leica 50mm f/1.4 Summilux M ASPH if you check the link.
Sorry for not being clear. I did mean the asph version. It's quite a bit older than several of the other fifties listed. [original post revised' thanks]
I was rather hoping you did mean the older version, which is the one I have, que sera sera.
On the original @Lens Rentals I did find it very interesting how the astigmatism of the f1.5 Sonnar went from a soggy bottom 240 wide open ( not that wide in this company) to a better than all the rest 24, including the Otus, at f2, that's some change, but OT 🙄
Appreciated.sent you a pm (didn't want to lead things too far astray)
Yes, there is a significant focus shift on the Nokton. But I am referring to the curvature of the in-focus plane, which can in some cases be disturbing at middle and far distances in general photography.But, for Lss, the lens shifts noticeably backwards when closing down (see the second picture in the OP). Maybe this is what you were seeing ?
