The Nokton 50/1.1 Revisited
Sony A7II, Voigtlander 50mm f1.1 Nokton VM lens
Nihon Odori Avenue - Yokohama, Japan
I have been thinking about this lens for a couple years and finally bit the bullet and ordered one from The Photo Village. They seem to have almost a continuous supply of used one's listed for $680 to $745.
I also have the latest version of the 50 Summicron so I will be giving the two a good comparison but from rereading this thread, it seems to be almost as good as the standard 50 Summicron.
I purchased a mint MP240 in January so am excited to see how it works on the new digital. Honestly, I purchased it for my daughter's wedding at the end of May. I also have the first version of the 35f1.2 so I think I am covered.
Guys, Can some confirm if the updated the f1.1 Nokton. If so, is it just a cosmetic change?
Afaik the Nokton 50mm f/1.1 is never updated. It is a great lens and has four advantages over the Leica Noctilux f/1: much sharper, no vignetting, much lighter weight and a much lower price.
Announced by Cosina is a 50mm f/1.2 aspherical lens (not an update of the 50mm f/1.1 lens wich is not an aspherical lens).
Erik.
I have so much affection for the Voigtlander Nokton 50mm f1.1 lens; it's a dream come true for capturing dreams coming true.
When the weather turns bad, the skies turn grey, the mood becomes foul... it's time to break out the 50mm f1.1 and seize the day!
Erik.
Robert White is advertising a new improved Nockton f/1.1.
https://www.robertwhite.co.uk/optics/lens-mounts/leica-m/voigtlander-50mm-f1-1-vm-nokton-lens.html
There is no new Voigtlander 50mm f1.1 Nokton VM lens.
What are you talking about?
All the best,
Mike
Hi Mike
I don`t know …. just read the thread about is there or is there not (post 85) and decided to look for myself only to see Robert White describing a new improved Nockton as per attached link.
Clearly this fails to clarify the issue.
Michael
A suggestion for those of you that are fighting the slippery focus ring, wrap a medium size rubber band around it. This provides s different tactile feel when moving from the aperture ring and solves the "slippery" problem
