Yokosuka Mike
Abstract Clarity
Voigtlander 50mm f1.1 Nokton VM lens, Sony A7II
Yokohama, Japan - March 2019
Mike
Mike
I don't think I will change my f/1.1 for an f/1.2. The f/1.1 seems to be sharper @ f/1.1 than the f/1.2 @ f/1.2.
Erik.
Maybe, just one thing of new f/1.2 has better: .70cm minimum focus.
For portrait/isolation can be worthwhile.
Cheers
Yes, and no. At 0.70cm the dept of field of a 50mm f/1.1 lens is very thin, maybe too thin. The picture will be almost completely blurred.
I love Mikes photo's here that show the incredible sharpness of this lens and also its incredible bokeh.
Erik.
Stunning sharpness. In the second picture, on black background show an yellow bubble with aperture blades at the borders. Remember me an your post on similarly picture, that at f/2 did show the same behavior:
https://www.rangefinderforum.com/forums/showthread.php?t=76156&page=3
"I do not very much like the sharpness of the confusion-circle of the specular highlight in the out of focus background. The confusioncircle must be unsharp because the sharpness contredicts the feeling of dept. Also the clearly shown aperture blades at the borders of the specular highlight are ugly."
Erik.
Yes, that was ten years ago. I still think that in situations like this full aperture is better. A sharp oval is less disturbing than ten sharp aperture blades. The problem with a rangefinder is that you can not see the effect in the viewfinder.
However, most of the time the Nokton gives a beautiful image, better than the f/1 Noctilux with its unsharpness and black corners.
Erik.
Leica M3, Nokton 50mm f/1.1, Tmax400, printed on Adox MCC 110.
Erik: have you tried using the Millenium Nikkor 50/1.4?
I have a CV 50/1.1 too.
I do not have experience with modern Sonnars, but quite a lot with the old Nikkors from the Nikon rangefinder era. These lenses (in fact copies of the old prewar Sonnar) are for me problematic: the 50mm f/2 has quite a lot of barrel distortion and the 50mm f/1.4 has unsharp corners at all apertures (but no distortion). Therefore I use on my rangefinder Nikons only the superb Voigtländer S Skopar 50mm f/2.5.
The Nokton 50mmf/1.1 is not a Sonnar-type, but a development of the Xenon/Summarit/Summilux v1 50mm lenses.
Erik.
No Raid, I am sorry, I never tried that lens (Olympic/Millenium). Usually they are very expensive. If I am right, that lens is not a Sonnar type, but a Gauss type. I am not 100% sure of that. The formula of that lens is unknown (see the books by Robert Rotoloni).
Erik.
I bought it with a camera just to get the lens. Some have claimed it to be as "good" as a Summilux. It is as costly as a new CV lens. Not more.
Erik.
