kanzlr
Hexaneur
I just use it. not every day as I do not have time to shoot that much, but I use it regularly and I am very happy with the results. I just need Vuescan support to arrive to be in scan heaven 🙂
I've been using it regularly until tonight when it appears to have crapped itself. when I power it on it emits a loud buzz and silverfast is unable to operate it.
tried a few obvious things (e.g. rebooting, removing power cable etc) but nothing work so far.
will let you know how I get on with plustek support...
I scanned an USAF 1951 target with the Plustek 120 and three different holders:
35mm slide holder
35mm film holder
6x6 film holder
in two different settings:
5300 dpi mode
10600 dpi mode.
My scanner will be replaced due to the delay in working of the green and red channels. I will compare the resolutiuon of the new unit with the old one using the target and hope for no focus problems.
New RFF member here. Even though I don't own a rangefinder.....this seems to be where all the Plustek 120 discussion is.
I have my doubts about using a film-based target to accurately measure this high of a resolution. It may actually understate the resolution to some extent. I think I read that the Lasersoft targets are shot on Agfa RSX 50, but take a look at the MTF curve of any slide film, and note where it is around 104 lp/mm (5300 dpi equivalent). The film itself isn't accurately recording the test chart at that high of a spatial frequency.
--Greg
Why not share the cost of a target.. or rent it out?
But 10600 dpi mode gives no significant advantage in resolution, so 5300 dpi mode is sufficient.
But if the focus will be perfect 30um and keep the found position rock stable all times after.
I was very keen to get this scanner immediately but Oz is a long way from the supplier and getting one with a problem would be frustrating.
When focus and reliability issues are settled ... for sure because I think the potential is there.
Thanks Greg. Very useful information !
When searching for USAF 1951 glass targets i also found a shop called Amoyca. But the price there is also steep, $ 129,--. Guess i have to study the theory behind the slanted-edge target a bit more as that sounds like a cheaper option.
Until someone like lensmate who are specialized in precision manufacturing from aircraft aluminum 6060 T6 or similar will make glassless, and perhaps with ANR glass holders for this scanner you can't be serious to achieve
CNC machining will be too expensive to use, we need a form to be made so that molten aluminum can be injected under pressure into it. Making a perfect copy every time.
The aluminum needs to be anodized black color to make sure there are no reflections.
If Plustek would come up with this type of holders as a FIX to this misalignment problem then that would be best for everyone !!
Come on Plustek make normal holders !
