The viewfinder glass piece.....I lost it...
Bill Liss
9:44 PM
W. ME/Boston/Schenectady
So, I realized suddenly the other day that I had lost the round glass screw on piece that covers my R2m viewfinder. No chance of finding it. I suppose I'll need to order another one. But, are they what cameraquest refers to as eyepiece diopters? and he lists several magnifications, which comes standard with an R2m?
and in the meantime, how will its absence affect my shooting?
any and all help appreciated.
Matthew
Matthew
I suggest you give Cameraquest a call. They can send you the correct replacement part.
If there is one thing you have to take care of with a Bessa R2M it is this rubberized eyepiece. It is easily lost and a spare part is very expensive. Look at it as often as possible and be sure that it is fixed.
Thomas
You do want a diopter, just one with zero correction. Yup, I've lost one as well and had to shell out £10+P&P to get another...
I check it often now, if I could be bothered I'd put a little glue in the thread.
The only thing the glass does is help keep dust out of the RF/VF. If I remember correctly it's the same as the FM1, 2 and 3 and FE Nikon glass. My ZI takes the same one and fell out the second day I had it. I discoverwed it was gone and retraced my path and found it in a parking lot where I thought it might have fallen off. I tightened it finger tight and have had no problems since.
As x-ray says, it just scratches up your glasses (if you wear them) and may get dirt inside your rf mech. Saying that when I lost it on my R2a the window behind the diopter looked competely sealed anyway - so I suppose it's just a scratch protector and diopter corrector is required.
Try this, use nail polish on the threads (just a little bit now) and while its still wet screw it on, been several months and mine is still there.
It may be simply worth asking around this forum and seeing if someone smiles on you. I recently got the R4a and took this piece off immediately as I use dioptre correction eyepieces. It may be that others are doing the same
The plain replacement ones are expensive for what they are. I've already put mine on ebay, but postage costs will probably not make it worth your while as I'm in the UK
Can anyone in the US help him out
Glyn
