RayPA
Ignore It (It'll go away)
Wayne R. Scott said:J...I will second or third the recomendation to use Diafine. Dead easy, quick and great results...Wayne
you can have the second.
Wayne R. Scott said:...Just a small word of caution when using HP 5 in Diafine. Expose at an E.I. of 800 instead of 400...
Isn't the Tri-X rating for Diafine EI 1250?
f/stopblues
photo loner
Here's a little update:
My scanner doesn't handle 120 negs, so I laid one in the flatbed with a white sheet of paper behind it. Then I just inverted it and desaturated and this is what came out. I do this once in a while just to check out general composition, etc before making an actual print.
I know thin negatives scan better than they print, but I don't think its as bad as I feared. Only the darkroom will tell!
dnk512
Wayne: I do pre-soak ilford and I see the purple stuff come out when I empty the pre-soak water. I have no issues after that. I used to not pre-soak and my final negs were more purple than I liked them to be, though all scan fine. So, what is the right way? What should I look for?
titrisol
Bottom Feeder
Prewetting any film has similar effects, Ilford are no exception.
While Ilford reccomends against it, it is a part of my SOP and haven;t had any adverse results with Ilford films and presoaking. It is like "half a dozen or 6 units"
Dev times need to be extended a tad but not real problems.
That scanned image with tha piece of paper in the back looks awesome.... wish we could give such efects in the wet darkroom.... any ideas?
f/stopblues said:I like your sig titrisol![]()
No presoak by the way. Ilford has that "wetting agent" so I've steered clear of that for this film.
