The hole on early Leica baseplates hooks over a smaller pin or stud on the body than later models, where the pin or stud is 5mm in diameter. Of course I may just be reading the pin wrong in your pics.
The pressure plate looks early but is not the sort with a hole in. Then again, the pressure plate design apparently changed several times in the first decade or so in an attempt to get better film flatness.
The lens is intriguing... the 2.5 Hektor was an early lens; most that I've seen had the "11 o'clock" Infinity lock. This one has a "7 o' clock" Infinity lock, suggesting it's either a late version of the lens, or was an early lens sent back to Leitz to be modified to work on the model III.
Very lucky find - the camera body shows the most minimal traces of brassing, suggesting it was not used a great deal !
You have it correct, you are taking the baton from your father and hopefully passing it along to the next generation. Congratulations on a wonderful discovery.
