I had a chance to play with a ZM recently. This camera is begging to be converted into digital.
Indeed, the view finder is every bit as good as a Leica M. Leave it alone and let me focus the lens. Add a screw-on magnifying eye piece for life-size 1:1 view…let the 50mm and 85mm lenses also shine.
The sharper-sounding automatic shutter is just as quiet as an M. I would adapt the dial for ISO control, and operate AE or manual as I please.
I would leave the manual film advance alone…let me do some things Epson RD1 style. A nice option would be an add-on motor to cock the shutter. 4~5 FPS is fast enough to support manual exposure bracketing.
The cavity for the unneeded film cartridge is the perfect place for batteries…hopefully 3 or 4 AAA rechargeable cells interchangeable with store-bought disposables. The film rewind is the perfect place for a screw-on sealed battery hatch.
The unneeded film take-up spool is the ideal space for dual SD memory chip Nikon D3 style…one for RAW and one for JPEG, or double up for higher storage capacity. Imagine dual 8Gb SD for bracketing at will. No film/processing cost is the perfect reason for such operations.
I would urge Zeiss to use a full-frame CCD…allowing usage of all available M-mount lenses without crop factor. 4500 x 3000 (3:2) 13.5 MPixel would be sufficient…allowing also 4000 x 3000 (4:3) and 4496 x 2539 (16:9).
Don’t bother with LCD screen, a million buttons and all possible features, real photographers don’t need those gizmo. An external wire-linked LCD with a large screen for review also doubles as a waist-level low-level view-finder would be useful, just plug it in when needed.
This way, the camera would not be larger, heavier or more complex. I will do the lens focus, set the exposure and bracket, or select AE or auto-ISO if deem appropriate. Free me to be the photographer I want to be; and not Imaging Device Input Operator/Technician (IDIOT) relying on automatic everything.
I bought a ZM with a 40mm/1.4 CV lens a few months later. Knowing and double verifying that the ZM framelines are loose (~85%); and under TomA's kind advisement, I had immediately filed down one of the bayonet claws to bring up 35mm frame lines (took 10 minutes)...a tight, almost 100% coverage Nikon F2 style.
Having played with The ZM for a year and a half, I might add the following thoughts:
The ZM finder is at least one f-stop brighter than my M2. Its far better eye-relief encourages users to be sloppy...hence perhaps comments that the patch might disappear unless you center your eye in the viewfinder.
The RF has a longer "reach" than Leica...next city block is not yet infinity, more like across the harbour and then some. I mounted my Nikon DG2 2X eyepiece magnifier (same thread size as the ZM) and carefully checked. Perhaps that was why some thought their RF is out of adjustment.
For the long-awaited ZMd, the only viewfinder suggestion I would now make is that Zeiss at least somehow adds an internal eyepiece magnifier in the viewfinder...the hump in the top plate is the perfect location to place a rotating control ring.
Hell, Zeiss could even develop a one-frameline zoom viewfinder starting at 0.5X (good for a 25mm lens) and ending up at 1.4X (making the viewfinder 1:1 and good for 85mm lens or longer). Nikon did an external one decades ago. Contax G/GII even had one built-in...didn't Zeiss have a hand in it?
"Full frame" might be the new holy grail, but digital format size can also be measured in terms of pixels [Leica S2 style]. If 3000 x 4500 is enough, then a 6 micron pixel chip will become 18x27mm (a crop factor of 1.333 for lens focal lengths, sounds familiar?).
If Sony [whose partnership with Zeiss was renewed recently for another 5 years] will play ball, didn't Sony make a full-frame sensor for its A-900 and said to have supplied that chip [modified by Nikon of course] to the D3X?
A "neutral" party Kodak has for a year now a 50Mp 6 micron chip (8,304 x 6,220)...big enough to be
re-cut into two 4,152 x 6,200 chip; and full frame in physical size. I am sure Kodak will never build a Chinon-made camera using that chip; and will welcome a big enough purchase committment...Leica M8 style.
Zeiss is optics...for far over a century. Micro lens [as used in the Leica M8] is merely applied
simple optics. Zeiss will do well working in that area...if it cannot come up with an even better solution.
Speaking of external LCD, I am sure an iPhone App could be developed...all it's doing is reading the camera SD chip directly as if it was the iPhone internal flash memory.
If a built-in LCD must be provided, the newest OLED display panels are far thiner, already used on a few new camera/devices and soon big TV's. The sensor/circuit/LCD package could then be as thin as 10mm...protruding from the ZM body a mere 4~5mm. I can live with that.
Adding an "A" setting in the current ISO dial is no hardship.
The current ZM exposure counter can be replaced with a LCD "exposure/battery remaining" display. If the film winder is indeed discarded, the available space can be used for an easier-to-read combined white balance, digital format and exposure/battery window RD1 style. [Hell, the battery remaining window could even be placed at the current film cartridge window.]
AND, a master on/off switch is already built-in in the ZM.
The Leica M8 proved a manual focus digital camera can be accepted...why not then a ZMd with the current lenses.
I have high hope that Zeiss might answer our prayer at Photokina 2010.
