S
sfaust
Guest
PS: Stephen, I'd love to hear from you any advice, tips, etc. you might have on how to make digital images look more like film. This is one of continuing struggles with digital...
One of the things you will struggle with are P&S cameras for all the obvious reasons, but also some that people may or may not be aware of. The sensor in the camera is basically your film. P&S sensors can not match the quality of the larger high end sensors. They are smaller, not as sensitive, have more noise issues, etc, all which translate into lower quality. But most P&S cameras are also aimed at the consumer crowd, and much like the super saturated films were, the cameras are tweaked to produce saturated contrasty and sharp images. When you move up to the professional level sensors, the images a cleaner, less noise, and less 'tweaked'. The fact that you can also shoot raw helps a great deal.
To give an image a film like look, first its best if you shoot in RAW. You also need to understand Photoshop levels and curves fairly well. This helps you massage the various layers to fix the contrast and saturation of the image. Adding in some film grain will also remove the tell tale sterile quality of a digital image. And playing with the sharpness to reduce it, but still maintain a sharp image is another step. Usually its done by sharpening and blurring individual channels to achieve a more realistic look. Its beyond this thread to go into all the steps, but the above is basically one of many ways to achieve that look.
If people see very clean, sterile, high contrast, and tack sharp images, they assume its digital. But, if you remove the sterility, match the contrast and saturation of a given film stock, add in some real grain, and reduce the sharpness just enough, it looses that immediate identification with digital and will pass most peoples radar.
But what most people with digital cameras do is quite the opposite. They increase the saturation, over sharpen the images, and add more contrast. And there is no way that will ever look like film.
If you really want to purse the film look with digital, I can dig up some old pointers to good tutorials on the net that if followed in Photoshop will result in an image that will easily pass as film. Just send me a PM.
