Juan Valdenebro
Truth is beauty
Marlon, do you know in which context did Garry Winogrand say the words you have in your posts?
Thanks!
Thanks!
If I were going to start with TriX in Rodinal I would use 1+50 at a specific time, etc. The enclosed sheet with your Rodinal has good times that to me seem accurate. There are plenty of problems with stand development, one with TriX is with roll film; not all the lighting is consistent so you get a flattening of the tones on some frames, then there is bromide drag, uneven development, and probably more (plastic reels). Many people use stand and get great results (even I have) but it is much more rewarding to have something that works almost every time when you are starting out.
How do you mix this? You take 2oz of rodinal and add in roughly 100 oz of water to the one gallon containers, to make 1:50?
So I got a bottle of Rodinal and I am about to make a batch to start developing and here is my Q...
One experiment I want to try is water bath Rodinal: higher contrast scene in Rodinal 1:50 for ~ 7 minutes, then ~10 minutes in a water bath. Those are starting points by guestimate, try at your own risk, no liability assumed.
^^^ except if you use 1:100 with little (3 gentle inversions every 3 minutes) or no agitation. Then in a high contrast scenes you get wonderful tonality throughout the curve. Just make sure the shadow values get adequate exposure.
