Tried an M6
italy74
4:24 PM
Northern Italy
Ok, taking advantage of the saturday morning, I went to the only local shop who keeps Leica stuff. Not exactly close but not necessary to go to Milan as well - which would require half day between gone and return. I can't get it for now but I really wanted to see by myself a few things.
He has both collectible cameras (MP / M6) and "common" M6 with a .85 VF. I tried with a Summicron 50, I guess it was from the early '70s, and here's what I found about it, once batteries were on.
First of all, handling it was like handling a cigarette-box-sixed brick. Very solid and pleasant, up to the expectations.
Second - what worried me more - the viewfinder: wearing glasses, although thin, it was quite difficult for me to see the 35mm framelines, but the good news is that both the patch and the framelines themselves were clearly visible otherwise. Probably, if i'd have to design one from scratch, I'd avoid both the 135 and the 75 framelines, which in the 50 resulted to be quite bothering. 50mm framelines were just right, though.
90 mm were adequate .. at least I thought it was much smaller even if the 90 I saw a few days ago into an M3 were even better. Unfortunately M3 is as beautiful as not exactly suited for me ( I'd like to have at least 35 mm framelines AND some kind of metering reference)
Third, the metering arrows. Definitely bright although I was viewing them inside the shop so not against the sun, however I feel they were ok for practical use. Something that puzzled me a bit was the fact I expected that the meter worked (retake a metering) every time I half-pressed the shutter while it looked to retain the first metering for a while. At least, the arrows suggested that.
Fourth, the click, nay the "CLOP", definitely different than any SLR (the M3 I tried was closer to a "SNICK"), probably not as quiet as I expected (see the other thread) however quite discreet for sure.
Fifth, I was finally able to look inside the camera as concerns the film loading and finally understood that strange way only Leica has (for what I know), and I also understood why someone says to ply the leader of the film so that it fits steadier in the takeup spool I guess. I guess experience may help a lot in changing film faster than the other way. I saw expert photographers of both systems able to swap rolls in less than 40 seconds (youtube videos)
What I found a bit awkward was the ISO setting. Although you have to do only once every roll, it's kind of time consuming and not as easy as expected because you have to work with your index finger only and you have to pay care about the turn you do. Probably, an outer dial instead of a finger-driven one, would have been easier to operate.
Bottom line, will continue looking at it, M6 .85 (and I guess M7 and MP as well) looks really worthwhile cameras for work. Read it correctly, of course they are, it's just me who have to understand if they can fit my work style (especially seen the price) and the answer is positive.
My first Leica experience was kinda disappointing. I was expecting the camera to be the size of a Canonet G-III but it's bigger. The shutter, however, is quieter than any SLR's.
After having owned now some more M bodies, I can report that their shutters are all different in tone, volume and timber. One of my cameras is a distinct tenor, whereas the other is a baritone. Keep in mind that when it comes to taking the photograph, you do hear the shutter, but your subject won't. That's the silence people talk about.
I'm glad you liked the M6. I wear glasses, and not seeing the 35mm frame has never bothered me. In fact, I like it.
Now, you have given me one more good reason to go to Italy. 😉
I have three M's (M6, M4p, and M2)..... they all sound different when fired and they have different frame lines but they all work wonderfully and the quality feel is there in each. I don't relay on camera meters so the M6 seldom has a battery therefor the arrows don't interfere with my view. I have never tried and M5 but I hope to someday.
All the Leicas I've owned have had different shutter sounds. The quietest to date is my M6 TTL.
With a .85 finder it will be difficult to see 35mm frames with eyeglasses, but I tend to just ignore the framelines and use the whole viewfinder as my 35mm frame. In effect, what you see is what you get. Works for me anyway.
John
I don't understand your post. You wear glasses and have a problem seeing the 35mm frame lines. You don't like the M3 because it can't be used with 35mm.. at least not without an external viewfinder.. but you want to look at a 0.85x viewfinder camera? Don't you want to look at a 0.58x viewfinder? I have an M6TTL 0.58x and wear glasses and 35mm and 50mm work great with this camera. The M3 works great with 50mm and 90mm. You can have the frame masking changed. I did this with my M6TTL so that only one frame line comes up at a time.
If you want a bigger and brighter viewfinder where you can also see the 35mm frame lines, then try the Zeiss Ikon.
I wear the glasses too, and I find the 35mm frame on my .85x M7 unusable, this is why I got a separate body (0.58x) for the 28 and 35mm. The .85x is perfect for the 50mm lens, once you get rid of the 75mm frame... (which I did). The problem may arise, if you will get stung one day by the idea of buying the 75 Summilux for portraiture... (which is what I'd like to do...). I am afraid, that I will have to buy the lens together with another 0.85x body... and this may be a good thing, because this way I have to keep my GAS at bay for some time...
John,
it's exactly my point of view. I too want to use what I see as what I get, thus it's fine for me too.
Francisco.. exactly what of my post pushed you to come here (although you're of course welcome?) - you know somewhere else I posted a few shots I took with my FM3A in Chiavari (eastern ligurian riviera) which is quite an unknown place to most tourist. Yet, I lived there for many years and only after having moved to where I live now I recognize the interest of such place, photographically speaking.
Let me shortly tell what I mean. If you have clear in your mind both Cinque Terre (especially Vernazza and Corniglia, my favourites) and Portofino, which are the two most famous places around here, Chiavari is a nice completion, although not "exclusive" like Portofino or with great sceneries like Cinque Terre.
The fact is that since ligurian towns are always build on a very little space compared to other cities, there are a lots of narrow stoney alleys, stairs and places also with great contrast in terms of lights and shadows which are usually interesting to shoot.
Namely Chiavari, who is a 30,000 inhab. town and has just been renewed, has 3 main attractives: its seaside which is very nice to walk along in summer and everytime there's a sunny day, the landscape you can have from the Middle-Age castle (well, more a watch tower than a castle) and the historical center.
Especially here you have the opportunity to walk along its main street and in the parallel ones, passing through its famous slate arcades. The hills behind Chiavari in fact have several slate mines and it's not by chance that the italian word for "blackboard" ( "Lavagna", in Italian ) takes its origin from the side town of Lavagna, where ships full of black slate left for the whole Italy in the past. Also, some of you might know that Columbus and Garibaldi, two of the most famous italian characters of the past, had their origins here.
And, while walking for the "Carrugio" (genoese dialectal word to mean "alley") you can have a typical meal for a very cheap price in the local "farinotti", kind of taverns, cozier and nicer than regular restaurants. What I learned to love of my homeland is the continous change of home colours, always very pushy and lively: pinks (exist a "ligurian pink" by the way), yellows, reds.. where green jalousies ( I know some of you from never seen them) look toward the sea. The good thing is that Chiavari is NOT the typical touristic city in itself. You don't have many "monuments" to see, yet is a town who has to be enjoyed differently.
Here's a shot of one of its most famous buildings: the so-called "Biblioteca Economica" a mix of styles - Portra 400 NC - Nikon FM3A - Nikkor AIS 28-50 F/3.5 at 28mm - 1/125s f/8 -0.3 EV (sorry for the wires in the sky, removing them without making a mess is still too hard for me)
Ciao
in fact the Ikon is another choice but I still have to check it.
I'm not complaining about the 35 mm framelines; as I just replied, it's fine I don't see them, since they anyway encompass the whole scene. The true question is - as you mentioned later, I might ever go for a 28 mm (Leica has a stellar F/2) which would make me lean for the .72x or the Ikon again.
Mostly I wanted to share my excitement, just this 🙂
A great point and one that people who think their cameras aren't as quiet as they think they ought to be should consider.
The shutter noise depends mainly on how tightly the shutter's been set by the tech. People tend to over tighten them to bring the speeds up, which is not the way to do it. I once had a Fed 2 that had been CLA'd properly (probably the only one in existence!, and I should never have sold it) that was so quiet, and the shutter wind on so easy and smooth, that I was sure it would not expose correctly. Well, it exposed perfectly.
I like the M6, but if I were getting a newer Leica I'd have to go for the M7. The AE is a real help, and it's generally just a better camera. But it's at a premium price too.
+1 Of the M-bodies I've used, the M7 stands out as the most versatile shooter of them all. And its shutter is the quietest too. If I were primarily shooting film, it would be my 35mm camera, no doubt.
I see, however my aim is finding a lighter and more effective (for certain works in low light) camera which is also more friendly (unobtrusive) to operate.
As I write these lines - and comparing them to what I wrote on another thread one year ago, I'm slowly changing my mind toward the M7, yet the Ikon and its ease to operate, bigger finder and attractive price is always there. While a M7 / MP à la carte would be wonderful, who wouldn't like one? it's also true I might spend the extra money for great lenses and this is something weighting again on the used Leica / new Ikon side.
I think I have clear what I need, although I haven't found a camera which fits all, except probably a Bessa R2A/R3A (under a strictly specs point) which is something not appealing me at all, so you see gear lust is also there and spot-on. 🙂
Looks to me like too much thinking about shooting with an M and too little actual shooting with an M. Pick one you can get for a good price, with the framelines you need clearly visible, and go for it.
I use M6 ttl .72 with 35 lux mounted all the time . I wear glasses and it's fine . For a 28 mm .58 finder might be better , although .72 is still usable .
I spent a lot of hollidays in Santa Marghuerita Liguria , my favourite place in Italia , from there you can make nice boattrips to Portofino ... and hotels are cheaper . Also love Torino very much . I like sitting on a terras and watch all those Vespas and Ducatis passing by ...
http://www.etiennemichiels.com
Ciao Koen, nice to see you here 🙂
actually I can't get any M since shortly I'll have more important expenses to deal with (international adoption with a double trip to Ethiopia), but later I know I have to get a certain amount of money, enough eventually to afford an M; this means that even if I could purchase one right now, it would be kind of "waste" if I can employ my remaining time to choose carefully the model I need and may get later. I have no rush at all.
@ E.M.: talk about "cheap hotels in S.Margherita" ! You make me smile... I saw some car boxes for sale costing up to 100.000 € out there... but of course I understand very well your pleasure to stay there. Liguria is as beautiful as expensive, not by chance we live longer than anywhere else in Italy.. we're the older region just because of the very favourable climate...
Eh, talk about coincidences, I was born in SML and spent there 20 years of my life...
I have both M6 and M3. I would like to keep one only and sell the other, but I really can't decide which one is fitter for me... we will see in a dozen of rolls.
Ciao!
Hi, Dino...
Never tried the M6 but still hope to own one someday. The M3 shutter sound is, as I have said before...
Seductive. Such a mistress.
Each shutter release is rewarded with the sound of a kiss.:angel:
Although I would not like a "clop" as much as a kiss, I guess I could used to an M6 in short order.
