Tripod mount counter balance weight?
mctenold
Photographer
7:35 PM
NYC
This seems like an odd issue, but I was shooting an event with my M6 and my SF24D, and I kept it around my neck.
The flash was causing the camera to be off balance and fall forward and upside down when hanging around my neck, which was really frustrating to deal with all night.
In my creative mind, I'm thinking just a simple weight that I could screw into the tripod mount on the bottom may solve my issues to make the camera more bottom heavy in this scenario. Or maybe the M6 grip could work?
Any other ideas here?
Again, I know this is a very odd and one-off issue. But who knows, maybe someone else has experienced this? 😛
Sure, that'll work but you'll be carrying the weight of another flash under the camera. One thing you might try is to fashion a little elastic band which would be like the rung of a ladder between the straps. This band might be a loop that you could simply slip over your flash to keep it from falling forward. The added weight would be less than two US $.25 coins.
Phil Forrest
Sent from my moto g(7) power using Tapatalk
I don't think the M6 grip weighs enough to solve the problem. I have a walking stick with a tripod screw that allows it to be a lightweight monopod. I have used it with the telescoping stick collapsed so that it doubles as a grip. By lowering the center of gravity, it is a sort of poor man's Steadicam. It could be a ready-made solution for you. They sell them both in camera stores and in outdoor supply places.
I believe that there has always been "Flash Brackets".
Ideal for off camera and bounce with reflector..
That what I did as pro, eons ago.
Personally I hate strobes on Leica-M..
If you just hang on to the M6 body with one hand, it won't do that.
Another solution - mount a Noctilux on the camera. The weight of the lens would provide enough ballast to keep the camera in the upright position.
