Guy Pinhas
Tri-X @1600 in Diafine with a pre-asph 35mm Summilux. I am pretty sure both were shot wide open. And sorry for the big files.
Pool at The Minds by Guy Pinhas, on Flickr
Calzone
Gear Whore #1
My next roll is loaded for shooting at 1250 (almost 1600). Thanks Cal for all the tips on TX+Diafine. I just got my first two rolls (mix of 800+400 w/filter) developed a few days back and scanned one in tonight with my Pakon. Grain looks nice and reasonable and the combo with the new 35 Ultron sings. Only negative is that I got a bit of streaking from the sprocket holes that needs to be sorted out. Going to post three obligatory shots here as a thank you:
Alan,
It takes about 25 rolls, but know that Diafine gets "seasoned" where the part "B" gets slightly contaminated with residual part "A." Know that seasoned Diafine delivers smoother contrast and mucho mids.
The best negatives are yet to come.
Also about exposure: when in doubt overexpose, otherwise thin negatives result.
Cal
Faintandfuzzy
Trix @ EI 1600
HC 110, dil. B, 15'15'', 30'' gentle agitation at the start, then 10'' every minute.
M6, Canon LTM 50 f/1.4
Hassun restaurant: customers (Kyoto, Japan) by Alessandro Saponaro, su Flickr
M6, CV 35 f/1.4 MC
Hassun restaurant: cooks (Kyoto, Japan) by Alessandro Saponaro, su Flickr
Beautiful. I will look at this combo and timing as well. Thanks.
flavio81
Great, great shots in this thread!!
My lab used to use Microphen whenever i requested a push for HP5 to 1600. It worked perfectly well, so good that i started telling everybody that HP5 is really "a 1600 ISO film" (it isn't true, but it worked so good...)
Tri-X should also work perfectly with Microphen.
flavio81
There is an older article - I don't remember where I saw it - about pushing Tri-X to 3200 and beyond. The author tried a number of developers, including some really odd super-soup combinations.
Google "pushing tri-x to 12800" and "super soup". It is a great article.
Calzone
Gear Whore #1
HC-110 is a developer I want to try. Seems like many possibilities.
Cal
Cal
Freakscene
Obscure member
The look of well-used Diafine is due to halide buildup in the A bath, not contamination of the B bath. You can figure this out by testing well used A bath with fresh B bath. But the well-used Diafine look is a very nice look.
Agree, on both counts.
Marty
Volver
Colin Corneau
Colin Corneau
I've heard good things for Tri-X with Acufine/Diafine.
You're going to want to at the least use a developer meant for push processing...I've had very good luck with Ilford's DD-X - with both HP5+ and Tri-X. 1600 should be easily done for either film, long as you use a suitable developer.
13Promet
Thank you!
I was rather impresed as well, as I expected very grainy and contrasty negatives.
I must say that I'm very glad about the overall rendering.
13Promet - those photos are very impressive. Shot at f1.4, what shutter speed?
Thank you too!
Sorry, f/1.4 is the lenses max aperture.
Both shots are @ f/2-2.8 (don't remember exactly)
Shutter speed is 1/60'' IIRC.
Cal
It's my first bottle of it, and I love it!
It suits perfectly my needs both for low and high speed films and I love the way it renders tones and grain.
Moreover, the cost per dev. is ridiculously low, it lasts forever and no powders to mix.
I short, I'd say it's a fantastic allrounder: I don't thnk that I'm going to try anything else!
Calzone
Gear Whore #1
Marty
Marty,
Thanks for sharing this info.
Seasoned Diafine is so smooth. Love the enhanced vast mids. This is where 135 looks like 120, and 120 looks like 4x5.
Cal
Calzone
Gear Whore #1
Thank you!
13,
It seems to be a very flexible developer and like you said, "An all-rounder."
It seems one of the keys to minimizing grain is to use strong developers and short times. HC-110 offers a lot of strength. Being a liquid also makes it easier, especially if one developes lots of film.
Microphen is another high energy developer, Acufine is strong and has very short times, and Diafine also has short times.
Minimizing aggitation not only provides a compensating effect (although times may have to be extended), but minimizing aggitation also seems to minimize grain size.
Jim Marshall's prints using Accufine and Tri-X at 800 ISO look very much like normal 400 ISO development as far as range of contrast.
Cal
