heronop2003
Universal View Finder is good and should have it? if i use zorki 4
varjag said:I must be slow today, but how UTF handedness affects parallax correction?
I recall seeing somewhere that if the finder is put toghether from parts of both types then the parralx correction works backwards from how it should. And you might not realize it until after you used it and saw the prints/slides/negs.varjag said:I must be slow today, but how UTF handedness affects parallax correction?
jdos2 said:The trouble isn't the handedness of the viewfinders, but if someone mixes parts, the right hand wheel on the left hand holder will be marked backwards for parallax correction.
heronop2003 said:Universal View Finder is good and should have it? if i use zorki 4
dll927 said:Sounds like you could avoid the whole issue by using individual finders for various focal lengths. True, this means more to carry around, but they would probably be more accurate.
