VC Hood on a ZM 35 2.8
taffy
11:38 PM
Will VC hoods work with the ZM 35 2.8? I have the LH-4 (round one) and I'm wondering if the ZM 35 2.8 can take it.
I am not sure what the LH-4 is for, however, the one for Biogon 35/Planar 50 works on Nokton 35mm F1.4..
Not sure if that helps,,,
Hiromu
Not sure if this will help you, but I use the VC LH-5 vented hood on my Biogon 35/2. The hood is a bayonet style and it fits the bayonet on the Biogon perfectly.
Cameraquest sold the LH-5 for use with the 40mm Nokton lens. I was initially concerned that the hood might vignette a bit on the 35mm lens. But I've not seen any evidence of vignetting.
I tried my hood from the 40f1.4 on the C Biogon 35f2.8. It does fit, though I don't know if it will vignet. The hood from the 35f1.4 Nokton (LH-6?) does fit on the 35f2.8 too. This one should be fine and not show up in the corners.
