krötenblender
Hello
I'm stuck... 🙁
Stupidly, I was trying to remove a bigger dust particle from the mentioned lens, and instead of simply unscrewing the rear element and blowing it out, for some reason I unscrewed the helicoid. Yeah, stupid me.
Now I'm simply unable to put it back together, because it seems not to be possible to find the entering point of the thread. I once found an entering point, but it was the wrong one, and the lens was not aligned anymore.
Has someone had the same problem and a solution for this? Or any useful advice? I'm thinking about sending the lens to Will van Manen and ask, if he can reassemble it. But I wanted to ask here first, maybe, there is a totally simple solution, and I'm just too stupid, to find it.
Thank you very much in advance!
Stephan
I'm stuck... 🙁
Stephan
