G
Guest
Guest
If any of you who have a problem with this can easily fix it yourself. I had one that was stickin and not returning to 1 when removing a used film.
Hold the film advance knob and LOOSEN the screw, open the back up and hold the inner part while removing the screw. Be careful there is a tiny round metal plug inside the threaded part.
Flip the film engagement lever to the right.
You can then see two tiny screws under where the wind knob sites, remove them.
The top is now loose but to remove it you need to use something to push the shutter release button down while simultaneously pushing in the small pin that was exposed after you moved the film engagement lever to the right.
Lift the top on the left side and push it to the right. The top now comes off easily.
I LOOSENED the screw holding down the rotating number dial SLIGHTLY and lubricated the gears, then tightened the screw just a LITTLE.
She now works like new. Hope this may help anyone, it’s very very easy.
Only issue is the viewfinder will fall off but it just sits on a pin and can only go on one way.
James.
James.
