Voigtlander 21mm with Filter. Is it OK?
ClaremontPhoto
Jon Claremont
11:12 PM
Alentejo
I'm just about to buy a Voigtlander 21mm f4 M bayonet lens.
Usually I keep a B+W skylight KR 1.5 filter on a lens as a see through lens cap.
Given the wide angle of view of the 21mm will the filter cause any vignetting?
Jon,
I use a Heliopan yellow filter on mine most of the time. It fits inside the small hood that comes with the lens. No problems that I can see. The hood protrudes a little further forward thatn the filter.
The only potential problem might be that the hood will not fit over(around) some filters. I have a BW 2xND and that one works fine as well.
Rob
