W/NW : Motorcycles
Finally got around to some decent pics of the Z.
Mamiya 7 80mm Acros 100 Rodinal 1:50 and orange filter.
Cheers - John
John,
I've been wondering how you've been getting on after those inevitable little teething problems one needs to fettle when re-awakening a long dormant classic. It is looking very, very sweet indeed. In an era when the Japanese industry were making some of the strongest motors ever, but seemed to sometimes put them into machines that might have been designed by a committee, the 900 still stands out as one of the prettiest, and most cohesively styled, models ever to emerge from Japan. As worthy as the Honda Four unquestionably was, the 900 demolished it, on the street, on the racetrack and, (in my view), aesthetically. And nothing could touch the big Z, when it was released—except, perhaps, its stablemate the Mach IV, if it was ridden by a brave or foolish pilot—and as an owner of both of the big Kawasakis, I can attest to this from personal experience.
The Rickman conversion is that rare example of a modification to a standard motorcycle that actually improves on the appearance of the original design exercise—I would award extra points, if stock four into four system was retained—but it's still gorgeous. Great shots, John. 🙂
Brett
John,
I've been wondering how you've been getting on after those inevitable little teething problems one needs to fettle when re-awakening a long dormant classic. It is looking very, very sweet indeed. In an era when the Japanese industry were making some of the strongest motors ever, but seemed to sometimes put them into machines that might have been designed by a committee, the 900 still stands out as one of the prettiest, and most cohesively styled, models ever to emerge from Japan. As worthy as the Honda Four unquestionably was, the 900 demolished it, on the street, on the racetrack and, (in my view), aesthetically. Nothing could touch the big Z, when it was released—except, perhaps, its stablemate the Mach IV, if it was ridden by a brave or foolish pilot—and as an owner of both of the big Kawasakis, I can attest to this from personal experience.
Brett
Hi Brett,
Just about over all the teething problems. Put in a new starter relay after having issues there (thank god for the kick start). After starting fine (once) it stopped starting! Found that a bunch of connectors near the blinker relay were loose. I think I will slowly go over all the electrical contacts and clean them. 40 years of road grime and dust even on this clean example. It does however need a tune. I think it's knocking under load. Having a ride next week with the local vintage club, so I'll see what they think. Time to look at the timing. Any suggestions for a good timing light brand that I can look for on ebay?
Don't worry the 4 into 4 pipes will happen as I noticed some surface rust already pitting the single exhaust. What better excuse?
Hi Brett,
Hi John,
You have actually reminded me that as well as ensuring the points are good, it is a really worthwhile move, when you put a new set into a Z decades after they were made, to also take the mechanical advance unit out and inspect and clean it. Even when the bikes were only ten or fifteen years old, I can recall needing to strip them down, clean them, regrease with fresh grease and re-assemble. They are pretty reliable units, however being on the side of the engine they eventually dry out the original grease and they can actually seize up, or, at least, stick a bit. This can make your ignition curve a bit random and, if they seize towards the advance end of the scale, the engine may run reasonable well at medium to higher rpm, but, of course, it will be over advanced at lower rpm. This can manifest itself as grumpy starting (popping, backfiring, reluctance to go first time). It can also lead to coughing and hesitation, stumbling as you feed throttle on at low rpm because it will be getting too much advance at that part of the rev range.
I can recall having to do similar maintenance on other Kawasakis of the same era such as some of the triples that used points (some models were CDI). After stripping, cleaning and lubing (maybe gently removing any visible signs of corrosion on the shaft if needed) the bike would run happily for a long time. The point to beware of (and it's been decades since I last did this so I'm relying on distant memories that may not be spot on) is that although taking the weights and springs part of the advance off the centre shaft is straightforward enough, I do believe it is possible to put it back on in two different positions 180 degrees apart. The catch, is that only one of them will make the bike run happily! Reckon I worked that out the hard way, decades ago. But when replacing points on a new to you bike, doing an advance strip and clean is a good idea, the first time, and every few years thereafter, because you can get the points gapped or dwelled perfectly and Eg the full advance timing spot on, (which is essential, of course). But in severe cases the advance parts can seize completely = no effective advance, fixed ignition timing! And even if it's just sticking, your timing at lower rpms will be at best, unpredictable, because it may get to full advance but not as progressively as it should and when it should.
Here's a shot of the advance unit I quickly googled. It's really just a spring loaded centrifugal system with two weighted arms set to offset the spring tension at certain rpms. As the weights extend, the outer shaft keyed to the inner one rotates relative to the inner one. Of course, the points cam is at the end of the outer shaft, so, as the rotation occurs, the point at which the points [edit: points, not cams] separate will be advanced.
There's a groove machined into the inner shaft as I recall. It's purpose is as a small well into which a small quantity of grease may be added during disassembly, after cleaning, so as to ensure smooth actuation.
Off the top of my head I can't point you towards a decent timing light as I've had mine for a good couple of decades, John. I'd be guided by specification as much as price, I'd expect there to be a gulf between best really affordable unit and best at all costs. I fully endorse using a timing light to adjust the timing, you can check it at various points of the curve and ensure all I have mentioned above functions correctly. It's the easiest and most accurate way to go. Having said all of that, if you are patient and fussy enough, and have verified that the advance is within spec, you can get quite decent results by setting the point opening up with the static timing marks at the correct gap. There was a time I used to do this before buying a strobe light, and although the strobe light made the task easier and quicker, I can't actually say my bikes really ran any better because I was pernickety about my adjustments. Some of the smaller triples like the S1 (the 250cc triple) and S2 (the 350cc) used to run three sets of points—each of which had to be spot on, for the bike to run well at full noise—and I used to set them up by the static marks and get them running perfectly. So yes, by all means get a light—but you can get the bike sorted pretty decently in the meantime simply with a 12 volt light and a set of feeler gauges if needs must.
Cheers
Brett
Scott two stroke twin
Rolleiflex 2.8C Xenotar/Fujifilm Pro 400H colour negative
BSA Rocket 3
Zeiss Ikon Contaflex Super BC & Carl Zeiss 50mm f/2.8 Tessar/Fujifilm Velvia (RVP)
Suzuki GT750
Rolleiflex 2.8C & Schneider 80mm f/2.8 Xenotar/Fujifilm Pro 400H colour negative
Velocette Venom 500cc
Hasselblad 500C/M & 150mm f/4 Sonnar on Pan F Plus in ID-11 1 + 3
Laverda Jota 1000cc tri cilindro
500C/M and 150mm Sonnar on Fujifilm Velvia 100
Ural & sidecar
Zeiss Ikon Contaflex Super BC & Carl Zeiss 50mm f/2.8 Tessar on Pan F Plus EI 25 in ID-11 1 + 3 13 minutes/20C
HRD Rapide
500C/M & 150mm Sonnar on Fujifilm Neopan Acros 100/ID-11 1 + 3 16 minutes.
I don't ride any more, but I still like bikes.
Hi John,
Here's a shot of the advance unit I quickly googled. It's really just a spring loaded centrifugal system with two weighted arms set to offset the spring tension at certain rpms. As the weights extend, the outer shaft keyed to the inner one rotates relative to the inner one. Of course, the points cam is at the end of the outer shaft, so, as the rotation occurs, the point at which the cams separate will be advanced.
Cheers
Brett
Brett, can't say how much I enjoy reading your replies and your wealth of knowledge which will help me immensely as I get to know this bike. I am cutting and pasting it all into a document to digest later 🙂
We must catch up if you ever are in Sydney (or Central Coast) I owe you a meal and beer or three.
BTW, great shots.
Cheers - John
Awesome bike.
It's been a long time since I lived and breathed Ducati lore, but it does remind me a bit of Tony Rutter's Formula Two championship winning Verlicchi-framed racer from the early '80s. There used to be a few replicas getting around the tracks of Oz a while ago (and, I'm stretching the memory banks, here, but I think there were even one or two genuine F2s imported too). I have no idea which this one is, but the discreet Sports Motorcycles sticker is a nice touch (they have strong historic connections to the marque, and one of its greatest moments, of course).
Cheers
Brett
Cheers
Brett
See here
http://www.hemmings.com/magazine/hmn/2009/07/Ducati-Dreams/1846833.html
I have an interesting mod on my older bike: it's a hybrid ignition system that uses electronics to deliver the power to the spark plug, but retains the original points to act as trigger relays. The power to the plugs do not have to pass through the points, only a very low triggering current. Google: "Hondaman electronic ignition"
My wife's 1975 Toyota used the same kind of setup. It had two sets of points IIRC to allow it to change the timing depending on driving conditions.
The R100 is with me since 1987; the R850 and R1200 were my last two bikes
For rme, BMW = flat twin and airheads are the nicest piece of iron that will last forever
Thread viewers
