mfogiel
back alley,
I find that taking out 2 bodies when I shoot and want to stay light works best.
I'd normally use the R4A with the 25 or 28mm and keep a 21mm lens in my pocket, and R3A with the 50mm, and keep a 75mm or 90 mm in my pocket too.
For a "full coverage", I'd bring a FM3A with a 100 macro lens and leave the 90mm and 75mm at home.
Another possibility, if you want to be fast and light, but don't need close up, is the R4A+21mm ZI+35mm and R3A+75mm.
I wear glasses, so the R3A with 40mm is unuseable, it is just useable with the 50mm, perfect with the 75mm. and with the addition of the 1.35 mag it becomes first rate for the 90mm. Make sure, once you get yours, to shoot a test roll of a ruler at 45° for the rf alignement with all the lenses you want to use with it. I've had some problems both with the rf accuracy itself with all lenses, and with a proper alignement of my 75mm Heliar.
