It doesn't matter for what you are going to use it. The only matter is how you are going to use it.
Press cameras are the only cameras which allows you to take 4x5 image handheld and quick. But it comes with limit. All you will get is 4x5 negative, which you will have hard time to develop and most likely will never able to print for real. Just scans or contact prints.
With frenchie camera you have in mind it is completely different.
You have to set it on the tripod, just like artist setting his blank on the tripod. And getting picture is almost the same in speed as getting it by the brash or pencil. You'll spend enormous time to find place where to place it secure and looking at the spot. Then another load of time to set it up. Then even longer time to focus, shift and compose. And then you will measure the light, but by the time you will get cable release in your hand the light is changed and you might never get same light and shadows placement in the frame again. This is why here is only few good landscape LF photos comparing to Polaroid ones. 😀
