What are your favorite "junk" cameras?
RML--really like the first holga shot!
A slight clarification:
I don't regard the Argus as junk cameras generally--My grand father and my dad both had their own C-3s and I started learning photography on my dad's.(first lesson learned: don't forget the interlock thingie when winding on. My first roll I got 36 shots on one frame and a bunch of teeny-tiny peices of film inside the camera. Luckily they cleaned out OK).
It is my specific example of the C-4 that I consider junk only because I haven't put the lens back together. It has worked very well as a pinhole camera. The viewfinder is fairly bright and ther is still OK contrast of the RF patch, the speeds seem pretty close but I mostly use B, the winding is smooth. I actually like the camera pretty well.
For pinhole use I simply taped a peice of brass sheet over the front of where the lens would be screwed on and I have saved the lens and set screw that were loose in the case when I got it.
So please don't misunderstand me; I am not classing the Argu(es)(Argi?) as junk cameras.
Rob
Well, a "junk camera" is hard to define, then... Let's see, how about a "Time" camera, all-plastic 35mm promotional give-away to new subscribers to Time magazine? It does work.
How about a "Yumeka"? Another plastic 35 which even came with headphones for listening to its built-in AM radio between -or maybe during- snaps. Still boxed, haven't run a roll through this one.
Junk... or eBay treasures? 😉
