David Hughes
David Hughes
I mentioned a couple of items and thought a picture, even as bad as this, might be better.
On the left at the front is a hot shoe for the OM-1 but not for the OM-1N. There's a thumb wheel under the word "fix" and the screw thread is one of the clues as they come in right or left handed.
Beside it is another fitting in place of the hot shoe that has a plug socket for using the flash well off camera.
These gizmos that screw into the top of the prism are made of black plastic that often cracks and inside it has two thin rubber or similar pads to protect the camera. Usually one of the pads will be missing. And the cracks may be very fine. Be very careful when buying. Take the camera body and check to avoid grief.
And behind them is a gadget that goes into the hot shoe and raises it a few inches. Very useful at parties to avoid red-eye and without the silly flashes beforehand. You can find these dirt cheap as no one knows what they are.
Talking of dirt cheap I'll repeat what I said earlier; an OM10 is a very cheap way of getting a back-up body with an OM system lens (often for the opening bid on ebay). And they have a hot shoe fitted and as the OM10 is part of the OM system I shouldn't need to say more...
Regards, David
Regards, David
