Gustavo, do you have the Digilux 1 or 2? If you have the Digilux 2 then I think you are referring to the Histogram display. The histogram display shows a 0-255 (0 = not enough light to register on the ccd or in a image and 255 being totally washed out white) d-max value. This tells the amount of light that is hitting each pixel on the ccd of your camera and relates it to a graph form called the histogram. I believe that the Digilux2 has a histogram that remains in the viewfinder and dynamically updates depending on the amount of light hitting the sensor (ccd). This allows you to change your settings (i.e. aperture/shutter speed) and see the resulting change in the histogram. Does this help out any.
As for the curves in the leica documents. The link below has a good article. There are others, just google "reading mtf charts".
