DNG
Film Friendly
Found my answer... YES, to both models... Good
Both have an option to leave the leader out on rewind.
So we all know that the Contax G1+G2 viewfinders are by no means amazing in terms of size and clarity. I did notice that for use with the 21mm lens, there is a separate viewfinder. If I got a 50mm external viewfinder for use with the 45mm lens, would the auto focus point be accurate using it?
Do you have a VF in mind that has a crosshair or something similar in the middle? or would you just guestimate the AF point?
The biggest negatve I can see is that you would be giving up one of the few "focus confirmation" --I use the term VERY loosely-- of the Contax G: the distance scale in the viefinder. While it's far from being a good focusing tool, you can at least get a sense of whether you are in the neighborhood or not.
One thing, jdos: what's in the G2 that you may miss in the G1? Other than second-curtain flash, 1/4000 as the highest shutterspeed, and (probably) a faster ftp speed? Sure, a larger baseline (concept I still haven't grasped) and size, but otherwise, it's the same titanium body with really easy film load, a bit of an annoying shutterlag and TTL flash metering.
Am I missing something? Please, advice. Thanks!!
