Which Ilford Chemistry?
stillshunter
unlearning digital habits
10:12 PM
Down Under
Guys I realise this line of questioning is not only tiresome, repetitive and subjective, but I could really use some help here. I'm returning to film and have so far been lucky enough to have someone soup my negatives for me, but it's time to stand on my own two feet. I have access to both TMax and Tri-X 400 film which I'm happy with - though am keen to try a few others in the coming weeks. Now after much research I'd settled on Xtol - but living rural here in Australia and having issues with delivery of chemicals to a PO Box - I'm now stuck with buying from a bricks and mortar store. My local store only stocks Ilford. So with ID-11, LC-29, DDX, etc., on the shelves which would you put in the basket?
I don't mind grain - hence why I shoot with 400 and film 😉 - but I also like creaminess (esp. in the mid-tones), nice shadow detail and reasonable (not over-the-top) contrast. Liquids seem the easiest to handle while I get familiar with the process, but I'd prefer not to compromise on quality - as I want to make sure these formative results are good ones that keep me as hooked to development as I am to shooting - so happy to mix powders.
Any opinions on Ilford chems only are much appreciated.
They're all good enough 🙂
For a start, I would suggest either ID-11 or DDX. ID-11 will need mixing from powder. DDX is more expensive.
Ilford Perceptol may reduce the film speed somewhat (depends on dilution) and will require some testing, so I would not recommend that as a start. However, once you've learned how to use it it's a superb developer.
If you PM me I can send you a 5L Xtol pack to get you started.
Marty
That's good of you Marty. 🙂
Xtol is a great developer and until I got seduced by the grain of Rodinal it was all I used. Easy to mix and relatively inexpensive!
I recently purchased a variety of developers other than Rodinal to test with Delta 100 and FP4+ 4x5. None of that is related to your question except for why I am looking forward to the results with Ilfosol 3 vs the others -- XTol, HC-110 and my standby Rodinal.
Peter Cameron uses Ilfosol 3 a lot and the results he led me to buy a bottle.
LC29 is developer letting jump start from zero - that's all I can say. As said ^^^, keeps well (strong + if you do not develop too often).
