Which Nikon?
rbiemer
Unabashed Amateur
8:35 PM
Clearly a Nikon, but F2? Maybe? Or a bit later? Kind of looks like an Fm2 but I don't know them well enough to really say.
I would really like to see the contact sheet from this.
Rob
Yes Graham Hill, a legend. Must have had strong neck muscles!
Rumour has it he would have a nip of scotch before a race.
He "died in action" as I recall, but which race? Agree about his neck muscles -- especially considering the G forces involved.
So how was the shutter tripped? I see some lever on the lower left of the bracket (i.e. right side in the picture) but I can't believe Hill would be taking his hands off the wheel and shifter.
Shutter is tripped electrically via the F36 motor drive. You can see the electrical connector low on the "rewind" side of the drive. It provided the electrical power for the drive as well as the shutter release.
I'm not so sure that the lens is a 28mm f/3.5. It looks more like the 21mm f/4 to me.
More likely the mirror-up only 21mm f/4 considering the subject material; a 28 would be too narrow to get the effect of seeing the view from the drivers perspective.
It looks too shallow for the 21. There is no dull chrome part at the bottom. Also, the first element looks larger for the 2.1cm. If it had a filter I would expect a reflection on the moniker not just the glass.
Looks like a Marty Forscher special if I was guessing.
B2
