Broughsup
broughsup
I could not get on with capture one at all, not even the latest version, so have junked it from my computer altogether and will stick with Adobe Elements 6 and CS3, particularilly like Bridge. Don
Maggie, you have the proper combination of C1 4 + Intel Mac + Leopard = Good. On the other hand, I have the combination of C1 4 + NON-Intel Mac + Leopard = Not Supported. Weirdly, it works anyway. 🙂
Doug
Mani, interesting — would it be possible for you to post a couple of files showing the difference in detail between C1 and RAW Developer, since most people swear that C1 reveals more detail than other raw developers, although I have not seen this difference with regard to Aperture.
—Mitch/Paris
Scratching the Surface©
My question for those of you who are more experienced with this than I am, is will shooting in 'raw' really make a noticeable difference, when the images eventually are going to end up about 800 or 1000 pixels wide?
If so, and considering that I mostly use Photoshop for image editing, is there a simple way to use the software from Leica to convert the 'raw' image into a jpg that I can then edit in Photoshop?
(A friend of mine has suggested that the latest version of Lightroom has all the information from camera manufacturers, that it will work just as well as the software from the manufacturers, and that most of what I might do in Photoshop I can now do in Lightroom. Do those of you who've tried this with an M8 agree with him?)
—Mitch/Paris
This is a dated thread but I'd like to point out for those with expensive Leica M lenses that Adobe Camera RAW and Lightroom (most consumer RAW processors) apply a default sharpening to all RAW images.
This is ok for cameras with kit lenses but if you want to see the true sharpness of your lens, disable sharpening in your RAW processor.
Why should I disable it, when images look better with standard sharpening. Oh wait, you were talking about expensive Leica Lenses. I only own Zeiss lenses. That may explain it. 😛
Actually, you should disable sharpening in RAW processor always because the artifacts that it leaves behind, even if its invisible to the eye will get accentuated with the final sharpening or during processing.
