Huss
Any water proof camera is only as good as the condition of its seals. If they are worn or old, the camera may flood. Even fresh seals can fail if they are not perfectly clean when the camera is closed. Perfectly clean = not even a single grain of sand.
There are a whole bunch of flooded/ruined Nikonos cameras on ebay.. Clue #1 is if they say 'untested'. Clue #2 is to check pics of the inside of the camera, any signs of corrosion means it is done. Clue #3 is if they don't post pics of the inside of the camera.
But, if you are only staying topside, not actually going into the water, then u should be ok.
