Roger Hicks
is if you're going to be making a lot of purchases (books, magazines, newspapers, etc.), the cost of the kindle itself is cheap relative to the content. So as crazy as this might initially sound, maybe buy 2, one for you, one for Francis. Buy one from the US, and register it in the US (some folks use a friends address, or even make an adress up, and fund it with gift cards), then get the 2nd one with European HW (they have Vodafone embedded sims instead of ATT, if 3G model), from either Amazon direct, or UK seller or reliable ebayer, wherever, and register that one in FR.
Then whenever you want to buy a book, or newspaper, check the availability on both, and purchase appropriately.
An added advantage, is when traveling, chances are one may have better 3G access to the web, depending on where you are. If you use google voice (not sure if it's available in Europe?), then your cell calls can be non-roaming as well, but initiated by the mini-browser on the kindle.
Hmmmm... Not a lot of purchases, I'd think, but the cost is fairly trivial and tax-allowable... Certainly worth considering, for the 3G alone. Thanks very much for the idea.
