Dante_Stella
Rex canum cattorumque
Ok... this is one I need to know, just so I don't go nuts.
Why do people insist on hacksawing the hoods off GW690IIIs and GSW690IIIs? It's not easy to get replacement hoods, and it's a pretty involved (and expensive) disassembly/reassembly to install a new one (hint: if you have to saw it off, it's because it can't be removed easily - you basically have to disassemble the entire lens barrel). I think the only reason I don't sell my GSW690III (which I don't use after finding the 50mm BL lens) is that I am beginning to worry that some amateur moyel would go to work on it.
But the thing that troubles me most about it is that there doesn't seem to be any rational reason to do it. The hood seems to stay out or in as required, and when retracted, it helps keep dust out of the shutter and aperture controls (and hence the lens). Aftermarket wideangle hoods don't have much better coverage, are bulkier, transmit impacts into the lens better, and are one more thing to struggle with.
I can only think of two rational reasons to attempt this. One would be using a polarizer with a handle. But those haven't been made for a while, and you can easily get indexing vernier polarizers (do you even really need a hood for a polarizer?). The other is using Cokin-style filters, but I can attest firsthand that even on cameras that lack built-in hoods (like the G690), this is a practice of questionable utility.
Well?
Well?
