Thanks Tim, I really appreciate you taking the time to post those links. Please share some pf your widelux shots in this thread.]
I'll figure out how to post photos here....haven't done this before.
In the meantime, a couple of my own observations about Widelux:
The Widelux filter set is cool in its fitted carrying case, but in these days of digital processing, the only ones really worth using are the UV filter, for high altitude and other UV-rich sites, and the ND filters, to compensate for the limited shutter speeds. The Widelux lens seems not to filter UV at all. I used to travel a lot with a Leica and the Widelux, and the difference in high-altitude images was striking. Modern Leica lenses filter all UV, no real need for UV filters even up in the mountains, but Widelux photos of the same scenes can really suffer without the UV filter. With the ND filters, you can stick with ISO 400 film for most situations. It makes things much easier if you are traveling and shifting between outdoors and indoors constantly. Another observation: the 26 mm lens in the Widelux (I'm familiar only with the F7 and F8) is really good. Because of the swing-lens design, the image is created just from the optimal central field of the lens. If you shoot with fine grain slow film on a tripod, you'll be amazed at the image quality. Can make large landscape prints that are edge to edge really sharp. Another observation: it helps to have a depth-of-focus table for 26mm handy or memorized. A big advantage of Widelux, compared to the Russian and other fixed-focus panoramic cameras, is that it has focus set at something like 3.3 meters (11 feet), while the others are set to infinity. This makes it easier to do portraits at near distance and still be able to do distant landscapes with reasonable f-stops.
Finally, some of my favorite books with Widelux images:
In Algeria, by Michael von Graffenried----stealth reportage
Pictures, by Jeff Bridges-----behind-the-scenes views of active film sets; he's made a limited-edition Widelux book of each film he's been in, and this is a selection. You know that Widelux is essentially a Cinemascope field of view, right?
Portrait of a Market, by John Stemets----scenes from Seattle's Pike Place Market
Signs and Relics, by Sylvia Plachy----street photos and personal; she has other books, plus years of photos in the Village Voice and New Yorker. Later used XPan, I think.
