PKR
The specific tricks you mentioned just wouldn't work. Lipstick would mar the strawberries, moving the pips and leaving greasy lumps, and while a hair-drier can be used to dry food, it ain't hot enough to crisp it. For the former it might be possible to use red dye in a perfume spray (though I'm not sure what it would do to the pips) and for the latter a hot-air paint stripper might work, though a blowtorch would almost certainly be better.
As I say, there is some fakery -- salt in beer gives a good head -- but I'd be deeply suspicious of a documentary which used the examples you gave.
Undercooking is normal (you just cook it some more for the hungry assistants afterwards) but one of my favourite memories was making Tequila Sunrises. It took five attempts to make a good one, and neither Frances nor I likes tequila, but one of our assistants did. She was quite happy by the end of the shoot.
The trick, incidentally, is to use a funnel. Start with it touching the bottom of the glass and raise it slowly as you add the grenadine syrup.
Hi Roger;
The head on a glass of beer is caused by bubbles forming around dust particles in the glass. I'm sure you've seen pub workers dunking a glass in water just before pulling the tap ? This is done to clear the dust so a full pint is poured (some or no head). It's also why glasses are stored upside down. To control the head, small amounts of dust are placed at the top portion of the glass (air bulb w/dust), where the head is wanted. Champagne is much more difficult to control. Many takes at a short flash duration are usually required.
The shape of the glass is critical for some beers to foam appropriately. I know more about beer foam than I need to. I'm not a food photographer or much of a beer drinker. As an assistant, I poured a fair amount of beer. One favorite AD drank a lot of beer, as glasses were replaced for fresh pours.
I don't know where these folks get their highly uninformed info on food photography? We both have practical experience in this field and, you must wonder, as i do, where this stuff comes from.
And, we all got some wonderful lunches, made from the food that was photographed.
